- Nov 12, 2004
- Transylvania
I am looking at an mk morse hole saw 3 & 5/8 in. (92 mm). I don't know if a regular bi - metal one from a hardware store will do the job. I found this one here:
http://www.mkmorse.com/carb2.html
The model: ATCG58.
Do I need to get a center arbor? Will the bi metal do just fine, or will it end up rough or cracking the acrylic. The morse one is around 40$ beans, but I don't know if it works, and how well it works, and if the money would be better served buying one of the terribly expensive Relton hole saws found here:
http://www.relton.com/holesaw2003.html
The model: ATCG58.
