- Jan 24, 2002
Hi,
A friend of mine has this problem:
Originally on his computer he had Windows 98.
Then he tried to install Windows 2000.
But because there was a problem with W2K he decided to go back to W98.
Now every time he boots there is a menu for choosing:
1. Windows 2000
2. Windows 98
eventhough Windows 2000 is not installed. And there is a timer for 30 seconds.
From what I know that is the W2K bootloader. I tried removing it by running "fdisk /mbr" but it didn't work. I guess it is installed in the partition itself.
QUESTION:
How do I remove the bootloader so that it boots directly into W98?
If removing is impossible then how can I reduce the timing to zerro seconds?
Thank you !
1. Windows 2000
2. Windows 98
QUESTION:
Thank you !
