Is it a Slot 1? If it's a legendary SL44Y, it can go way high. I picked up a used one with that stepping, and I got it to 157, 2-2-2- on a BE6II-RAID Rev. 2.0 with 2x256 PowMem PC-133. That's 942 mhz. I think it only needed 1.75 volts. That's waaay overachieving for a BO step. I'm talking 3D benchable here! It can go over 160 fsb/1 gig 2D stable except the Voodoo5 PCI card I'm running is already at 40 mhz bus with the 1/4th divider at 157 fsb. Forget about an AGP card, that bus is running 105 mhz!
I have another boxed SL44Y I got way back, never opened. I have these in mind for my dual Slot1 P4C-D board
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have luck with 600Es. I also have an FCPGA BO step that also does 900-950 mhz. I got it from Intel as a replacement for a 300 PentiumII that died.
I'm on air BTW, I think I have the #2 score on the CPU database not on water. Generally to hit >900-950 mhz you need at least water.
