How to chnage IRQ
YoungstaxGx
How do i change IRQ for my soundcard...im having problems.....its using TNT2/netcard/usbcontroller/ and audigy on 11 irq....and tnt2 netcard and audigy are having irq conflict how to i change the irq?
need help fast!
thank you:burn:
IRQ
What OS you got? Win2k and XP won't let you change irq's... they're managed by ACPI, so if you disable that then you can change irq's.
win2k is what i have....my soundcard does not work right.....i really want to try to change the IRQ , thats liek the only thing i have not tried...and it says the TNT2 / ethernet/audigy is having IRQ conflict (IRQ11) but only soundcard is not working properly
hmmmm maybe if i change OS it will work...i need my soundcard to work right because i do alot of recording/editing. Maybe if i change to windows XP it will work? I NEED IT TO WORK!!! :mad:
peace out :burn:
