The alcohol in rubbing alcohol is different than the alcohol one drinks. we're talking medical.... Isopropyl.
A little primer here on the different types of alcohol: https://sciencing.com/main-types-alcohol-7230415.html
I was wrong. Isopropyl alcohol is not made from food crops. It is made by combining propylene (a by product of gasoline refining) and water. But you folks there in Saudi Arabia should have plenty of that kind of alcohol. Do you call it something else?
Regular TIM between HIS and DIE won't bring any significant improvement.
Best is option 3.
Right.
Are you doing this or not?
If you are doing it, the only way is #3.
hi guys
I want to put an order on Amazon
thermal grizzly that is 1g a is the a separated from the main shipment and the also derive 6 days later so is it would be shipped separately and would cost me extra money from usa to Saudi Arabia.
So are putting the cart the thermalright would this also be a good brand for delidding cpu ?
https://www.amazon.com/dp/B07S8VK1NL/ref=cm_sw_r_cp_apa_i_-FHaFbHG6C6GT
Don't know anything about it but any LM product should work better than any conventional paste product.
I also found this a product but I don't know is it a liquid metal or thermal grease because the title says it is a thermal grease.
https://www.amazon.com/dp/B078J4PSHM/ref=cm_sw_r_cp_apa_i_GzHaFbM2BE7WP
From the pictures, it definitely looks like LM.
