how wrong???
The Stickie
Belgium
I know every temp reading is really wrong, but this is crazy:
I use MBM for temp reading usually, but...
I was fooling around with my pc: just have a new case etc. so decided to pump up temps...
got to 39°C, not cool, but hey not really bad either...
I rebooted, enetred my bios: 48° this really much hotter, but which is least wrong?
Can I correct it, and which temp should i consider the right one?
The Stickie (Jun 28, 2001 07:59 a.m.):
Make sure you have MBM reading the correct chip on the motherboard. If you goto MBM site he lists what chips should be used. I suspect if your BIOS reades 48 C and you MBM reads 39 C then you probably have Motherboard temp and CPU temp mixed up in MBM.
I have a pIII 666@750 with some fake Golden Orb-thing (it really sucks, I'm getting a new one soon)
temp with MBM was at FULL load
and my motherboard temp is only 32°C
