bafbrian said:Don't even consider the Thermaltake 11 HSF. Thermaltake HSF's are known to crush AMD processor cores. I've had this happen too many times. I believe there are other members here who have had the same problem with Thermaltake HSF's.
SF101 said:yea but glussier the volcano 11+ never even came close to the aero on that benchmark results list this site has
glussier said:
Where have you heard that? Certainly from newbies who don't know what they are doing.
SF101 said:hehehe i went to play a game on my pc and it was running like total crap im thinking like wtf i get gleeeeeek in my sound like the sound drags out getting screen lag and stuff
my mobo reset my cpu settings when i changed this fan lol it was running at like 100mhz fsb
so yea my cpu is idle at 39-40*C which is still 10*C lower and should prevent my system from going funky
still think i should change my ram though
what do you all sugest
?RAM that is
glussier said:
Lol, the v11 is not even in the list. The v12, which is a much better hsf than the Aeroflow is not in the list either.
Obviously he didn't update his sig, as he probably wasn't aware yet that his system was running at 100FSB, thus running much cooler.glussier said:How come, you show 39 to 40c idle temp in your post, but 34c in your sig?
As for you problem, check for driver problems (chipset, video or sound).
SF101 said:k
i tryed and it just quit
i duno why really i mean i check my system with sysoft sandra
it says everythings good
i use this program prime95 put it on blend or inplace large FFT's
and it like starts and quits before it even has time to go 1*C higher than 38*C
so i duno maybee the ram doesnt like it even though sysoft said ram ran fine in all the benchmarks
