- Nov 10, 2005
- Oxford
hiya
I have just bought a new set of mods for my comp, fans and stuff... including a new cpu fan...
I took the old cpu fan out, tried to put new one in, discovered that stupid thing didn't fit on motherboard (i'm not stupid, the fan would fit on others, and the socket is the right one....
Having just discovered that, i was going to put my old f/h/s back on, then realized that the order han't included the thermal grease i had ordered and i didn't have any more-leave that for now then. Next day (today) decided the thing would run anyway, and it did, fine. Temps mid 50's when I checked bios, fine and dandy.
Then having done that, I went to restart, and as it was booting, it died.
Since then I have had to take the power out, turn psu off, back on, put kettle plug back in and then I get a flicker. The psu fan gets one spin, as does the cpu fan, thats it.
I have taken ALL the mods out, cathodes, fans, nothing but HD, CD and cpu fan in, my mobo doesn't need the p64 power plug, in fact doesn't have socket so thats not in.
The mobo is a pcchips m848a or m848alu, not much difference, and sorry, but I cant rmember wich one, I think its the m848alu personally.
The processor is a AMD xp barton 2800+, not clocked. The fan is standard. Seatgate barracuda 80gb HD, winfast 340, fx 5200, 128bit.
Psu, which may well be the root of the problem, maybe loose connection? Is a COLORSit 550W golden silent... if that means anything to any of you.
Thanks for any help/solutions, blunt advice/telling me my psu's dead, whatever...
