Uhm... actually ganged and unganged have to do with the way that your memory is allocated to each core of your processor.
Ganged mode = All of your memory is available to all the cores of your CPU and therefore your memory is treated as one giant piece of memory.
Unganged mode = Your memory is 'split up' into chunks that allows each core it's own piece that it allocates to.
Most people see a performance boost with unganged, but it's actual purpose was designed to work better with multitasking as a more parallel system to multi core processors. Ganged mode is basically how it was done before multi core systems, when the memory was allocated by only one source. I don't think it has anything to do with how many channels you are running. I have unganged mode and dual channel in my rig. If you set the ganged mode, and your BIOS for some reason thinks that ganged mode and dual channel will not be compatible, it will choose one or the other as a sort of safe guard. You most likely have settings wrong in your BIOS, or your DIMMs are in the wrong sockets in order to operate in dual channel.
Btw, if you want dual channel, you need to put a DIMM in 2 different channels, not both in the same channel.
So basically, Ganged DOES NOT = single channel, and Ganged is 'old tech'... unganged is what you really want. Is there a specific reason why you wanted Ganged mode (I can understand the misconception, I originally thought it meant dual channel when I first started)?
