- Jul 4, 2012
It's been about 5 years since I did any cutting with a dremel. Do I need to keep the top of the case cool as I'm cutting into it? Would a powerful fan be enough, or do I need to keep pouring cold water on it and cutting slow?
What's the best method for cutting a hole for a 120mm fan? Should I print out a stensil and tape it to the case, then cut through the tape? Is there a better method? Should I drill pilot holes and cut between them, then buff with a stone?
I can't currently afford to buy a hole saw just to cut one hole, so this is the cheapest method I can think of. (cheapo harbor freight dremel for $8 and some diamond discs.)
I appreciate any advice someone with expreience has to offer. I'd prefer not to have to buy a new case just to AIO my graphics card.
Does anybody know if this circle cutter they sell would stand up to aluminum?
https://www.harborfreight.com/carbide-tip-adjustable-circle-cutter-68117.html
That looks promising.
