Fist of all my English is not my first native language, second im not really new at overclocking but need all of your help for overclocking the FX 8350.
Do you think that found my fastest FSB, can this be true?
I would start by setting your Ram frequency to 1600
Manually set your Ram voltage and timing to Manufactures specs.
Leave FSB alone for now, and overclock using just the multi until either;
A: you get to the speed you want it to be at.
B: your cooler wont allow you to go any faster.
After you found that "Target frequency" you want to be at, look to see how many volts it took to do it!
Then you can lower the multi and raise the FSB, to get back to that "target frequency".
Once you start raising the FSB you will need to add CPU_NB volts.
Remember while running Burntest's you want to keep an eye mostly on the CPU Packages..Dont let them go over 60c, and dont let CPU go over 70c
