HI new to forum and very newbie to overclocking. i just need some help trying to oc my i52500k so i can get the most out of it. my system specs are.
ASRock P67 EXTREME4 GEN3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9
MSI N580GTX Lightning Xtreme Edition GeForce GTX 580 (Fermi) 3GB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI
Sparkle Computer Corp GOLD CLASS SCC-850AF 850W ATX12V / EPS12V 80 PLUS GOLD Certified Modular Active, 0.99PF Typical ...
LIAN LI Lancool PC-K62 Black 0.8 mm SECC, Plastic + Mesh ATX Mid Tower Computer Case
and for cooling i use
CORSAIR Hydro Series H60 (CWCH60) High Performance Liquid CPU Cooler
my mobo has a preset oc tweaking in its bios. but from what iv read or heard from other people is that they put the voltage alittle higher then need. So if i can set it manually with less voltage to reduce the heat that would be better im guessing. but then again i wouldn't know how.
If someone can help me clock it manually that would be awesome
p.s my ideal clock speed i would like to hit stable is 4.2ghz
