- Jul 20, 2002
The BIOS setting explanation for my Asrock x99 Extereme4 indicates higher VCCSA is beneficial for overclocking memory. Does VCCSA also affect stability for high BCLKS that result in high QPI & PCIe bus speeds?
It seems in my testing that I've had to use 1.4V VCCSA to get stability (using a 0.55 V VCCSA offset) on my Haswell-E rig when pushing the BCLK to 132MHz (which I need to push the memory to 2900 MHz).
