guys i made it to 4Ghz
here are the temps:
LOAD intel burn test & prime 95
core#1-79
core#2-78
core#3-76
core#4-75
high rpm
core#1-70
core#2-68
core#3-65
core#4-64
here is the bios template:
Advanced CPU Features:
CPU Clock Ratio ................................ [21] (191X21)
Intel(R) Turbo Boost Tech ................. [Disable]
CPU Cores Enabled .......................... [All]
CPU Multi Threading ..........................[Enable]
CPU Enhanced Halt (C1E) ................. [Disable]
C3/C6/C7 State Support ................... [Disable]
CPU Thermal Monitor ........................ [Enable]
CPU EIST Function ............................ [Disable]
Bi-Directional PROCHOT .................... [Enable]
Uncore & QPI Features:
QPI Link Speed ..............................[x36]
Uncore Frequency ..........................[x17]
Standard Clock Control:
Base Clock (BCLK) Control .................. [Enable]
BCLK Frequency (MHz) .........................[191]
PCI Express Frequency (MHz) ............. [AUTO]
Advanced Clock Control:
CPU Clock Drive ..............................[800] ** DIDNT TOUCH THIS **
PCI Express Clock Drive ................ [900] ** DIDNT TOUCH THIS **
CPU Clock Skew ............................ [0] ** DIDNT TOUCH THIS **
IOH Clock Skew ............................. [0] ** DIDNT TOUCH THIS **
Advanced DRAM Features:
Performance Enhance .......................... [QUICK]
Extreme Memory Profile (X.M.P) ........... [Disable]
System Memory Multiplier (SPD) ........... [ 8]
DRAM Timing Selectable (SPD) ............. [AUTO]
Channel A + B + C
Channel A Timing Settings:
##Channel A Standard Timing Control##
CAS Latency Time ..................[AUTO] ** DIDNT TOUCH THIS **
tRCD ......................................[AUTO] ** DIDNT TOUCH THIS **
tRP ........................................[AUTO] ** DIDNT TOUCH THIS **
tRAS ......................................[AUTO] ** DIDNT TOUCH THIS **
CR..........................................[AUTO] ** DIDNT TOUCH THIS **
B2B........................................[-] ** DIDNT TOUCH THIS **
Advanced Voltage Control:
CPU Intel Core i7 930 D0 Stepping
Load Line Calibration .................... [Level 2]
CPU Vcore ......................................[1.300]=1.4
QPI/VTT Voltage 1.150v .................[1.275]=1.3
CPU PLL 1.800v ..............................[1.100]
IOH VOH ......................................[1.250]
PCIE 1.500v ...................................[AUTO] ** DIDNT TOUCH THIS **
QPI PLL 1.100v ..............................[AUTO] ** DIDNT TOUCH THIS **
IOH Core 1.100v ............................[AUTO] ** DIDNT TOUCH THIS **
ICH I/O 1.500v ...............................[AUTO] ** DIDNT TOUCH THIS **
ICH Core 1.1v ................................[AUTO] ** DIDNT TOUCH THIS **
now i want to get pass 4Ghz.like 4.2 or 4.4(that's my max target) i've seen people getting via air cooling at that point.with acceptable temperature.actually i did able to boot @ both 4.2 & 4.4.
but,when running intel burn test after 5 min the famous BS just visit me.
i push the v core to 1.4.didn't work.did manually changed the timing.but,if i change ram timing the pc won't boot.with following config:
7-7-7-20
7-8-7-20
10-10-10-28
so,people help me please going pass 4Ghz.@ 90 degree that would be acceptable to me.pls note i won't be using it for long time.just want to see how far this can be pushed.
here is my config:
Casing-Thermaltake armor
Mobo-Gigabyte X58A-UD3R(Rev 1.0) 3 way SLI/Crossfire
CPU-Intel Core i7 930@4Ghz
CPU Cooler-Thermaltake Frio
RAM-Corsair XMS 6GB DDR3@1600Mhz
GPU-MSI GTX 580 1536MB+Gigabyte GTX 285 1GB as a dedicated PhysX
ODD-ASUS DVD R+/-
PSU-Gigabyte Odin pro 1200 Watt, SLI certified, 4 way SLI certified, 80+
HDD-Intel x25 80GB SSD+1000GB samsung+250GB Samsung
Uploaded with ImageShack.us
thanks in advance
here are the temps:
core#1-79
core#2-78
core#3-76
core#4-75
high rpm
core#1-70
core#2-68
core#3-65
core#4-64
Channel A + B + C
7-7-7-20
7-8-7-20
10-10-10-28
here is my config:
ODD-ASUS DVD R+/-
thanks in advance
