- Dec 5, 2001
- Canuckistan
So, after looking what all im going to need to go through to get my system setup for some extreme air cooling, i've decided its just not worth it, and i can probably do better on water anyway. But im a total nub to water cooling, and this is where you fine folks come in
Now, i've been doing some poking around and im starting to get some ideas together. One thing to keep in mind, is my computer is close to a window, and what i'd like to do is have my rad outside to take advantage of the cold weather. I have some styrofoam insulation going in the window opening so i dont freeze myself out, and i'll be having the tubing run through the styrofoam to the rad outside, then back in. How much of an effect is going to have that i have to run 10-15' of hose to get to the rad outside? I plan on insulating the return line from the window to my case so my room temp doesnt warm it up much. I suppose i'll be needing a touch bit more antifreeze in my line, 60/40 mix as the temps have been known to hit -40c in my area. Is this going to be a major issue?
Aside from the cold weather mod, i've read some people saying that its not really worth it to bother with sticking a WBlock on the northbridge. I may overclock my northbridge a bit more, but im not sure if my ram will take it anyway, and im only seeing 31c from it with passive heatpipe cooling. But, the heatpipe that cools the northbridge is also tied into my mosfet sink, and i've been seeing that go over 40c, and i havent started pushing this cpu to what it will go, so should i just replace both? I remember seeing someone with a waterblock for the mosfets on the same board as mine, not sure where they got it though. For the northbridge i was looking at a Swiftech MCW30 going for $30 bucks, seemed cheap enough and i believe its hard-mount will fit. For a pump, im looking at picking up an MCP655. Seems like one of the better choices.
As for the cpu/gpu, i really dont know what to go with here, there seems to be alot of choices, and some of my choices seem limited shopping in canada. Also, the gpu blocks seem quite expensive, most having prices over $100, which is way more than im willing to spend.
Well, thats where i am now, suggestions?
