Install windows Xp in dell inspiron 5559???
elfaii
Hi,
I am trying to install windows Xp in dell inspiron 5559 with core i5 6200u but i can't, i take "death" screenn blue screen...:eek:
Can anyone help me to find the apropriate drivers for the cpu so to integrate in th copy of Xp and install them???
thank you in advance!
Tír na nÓg
When does it BSODs?
Have you tried changing sata devices from AHCI to IDE, or the other way around?
Edit: in the Bios, sorry for forgetting to add this info...
elfaii
elfaii
thank you for your response,
when the system try to find the hdd to install from the copy XP..
no it hasn't ide..
do you know if I will integrate the drivers for the cpu for windows 7 x86 maybe the system see the hdd in the installation windows XP
or it's false???
Tír na nÓg
Don't look at the open window: I got the picture from the internet. Check line 7:
"SATA operation": it will be either AHCI or IDE.
elfaii
elfaii
yes of cource you clear,
No it hasn't
It has ΑΗCI and Disabled ( = the SATA controlers are hidden )
elfaii
elfaii
i tried and it give me another error and also missed the dvd drive
Mr.Scott
Beamed Me Up!
You need a SATA driver at F6 on the XP install. Not gonna happen. There was never an XP driver made for that unit. W7 or newer is it.
c627627
c(n*199780) Senior Member
New laptop drives are formatted as GPT on which you cannot install Windows XP.
You have to reformat to MBR.
You have to set Legacy Support to ENABLED.
You have to mess with the BIOS...
You have to integrate AHCI drivers into Windows XP installation media.
Certainly not impossible but very involved, it can't be a quick install.
I am about to install Windows XP on a brand new Asus Skylake desktop motherboard.
Will post about it on here in a week or two.
elfaii
elfaii
Good morning,
Yes it is indeed, I thought that with above settings I can install windows Xp in the laptop with core i5 6200u but I can't!!
There no driver AHCI to integrate into Windows XP installation media so how I can do it?
I'll be waiting for yours news
Keeping in Touch!
elfaii
elfaii
yes i am ready but for which cpu_chipset is the Achi drivers??? that you had upload my is dell inspiron 5559 with core i5 6200u
anyway i gonna try and write back the results,thank you:)
c627627
Good question.
You can SELECT ALL all of the drivers there, press CTRL+A to SELECT ALL.
