Installed Ripjaws v on Asus x99 pro - not getting proper speed
VAROR
Hi
I have installed Ripjaws v (F4 -3000C15Q-32GVRB) on Asus x99 pro MB in quad channel setup. Though the native speed is 3000mhz, but the system only shows 2133mhz. When i am trying to select the xmp profile from bios it comes back to the original state after restart.
System config:
5820k
Ripjaws v 32GB
Asus x99 pro
Asus Strix 960 2GB
Is there a way to get the sticks working at 3000mhz?
ATMINSIDE
How are you saving in the BIOS?
Can you try entering the XMP settings manually?
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
I would manually add some SA and IO voltage (.1 each) because you have so much ram. Save, reboot back to BIOS, THEN enable XMP and see if it works.
Be sure the BIOS on your motherboard is up to date.
wingman99
If the other things you try from EarthDog don't work try increasing the ram voltage from 1.2v to 1.3v.
