Installing HP LaserJet 1200, Better to install CD then update or just install update?
Hello all i am connecting a 3 year old HP LaserJet 1200 printer using the LPT to a Windows 2003 Standard Server running as the Domain Controller on a 5 client network using Win XP Pro... I would like to know if you guys think i should install it using the old cd that came with the printer then update the drivers or just install it with the updated drivers?
Is one way better than the other?
I have a choice between PCL 5e or PCL 6 drivers... i am just going to be printing lots of text which do you guys recommend?
The updated driver is only 4 megs so i am thinking that i should install the CD because i would imagine it comes with special features then apply the update.
Thanks in Advance
Eddie
Thanks in Advance
Eddie
