- Dec 8, 2005
lee1026 said:Well, as electricity bills can rake up if you never turn the thing off, turning it off may be a highly good idea.
7.8cents a killiowatt hour for what.. 40watts, I don't see the problem.
Thats mostly due to OpenOffice itself which is not a native binary, rather it runs in a Java Runtime Environment, and like most Java based apps suffers for it.Bad Maniac said:I noticed the same with Ubuntu. My Dual P3-550 with 512 ram flies with Windows 2K, ubuntu takes almost four times longer to boot and runs noticably slower. Opening Word XP in Win2K takes seconds, opening the openofice wordprocessor in ubuntu takes much longer.
Had you made an argument for Ubuntu being compared to Windows XP I would have agreed with you, both Gnome and KDE are more advanced eye-candy wise than XP, and millenia ahead of Win2k.tenchi86 said:I think it's obvious Ubuntu should load faster then Vista, Vista is the next gen OS that requires an 800MHZ cpu just to run, Ubuntu on the other hand has for the most part has no visual effects. IMO Ubuntu would be better compared to Windows 2k. Atleast based on visual themes, and what is going on in the background.
Enablingwolf said:One thing that makes Linux advanced stock over competing Ms proioducts is what has been built in.
I think leaving the plain look is very accpetable. Since most will be tweaking the look to suite thier tatse./ Windows you have to add third party applications or hack the core files. Sometimes it even costs to do some simple really cool stuff in Windows. That is not the point of how advanced one is over the other.It is the underlying technology. Linux you start grabbing files and making the simple changes. I have to admit. I am used to the MS feel of the desktop/. Linux is by far more advanced in how the operating system handles tweaking it up to suite each users tastes.
A light example is the 3D-Desktop that is not hard to get going. There have been many attempts on the Windows side of the coin and every one is lacking in a nice solid GUI. Linux has that over the top and running rather well. Windows your getting a whole new shell to even start to get some true 3D like interface. Plus most the MS 3D type interfaces lack many functions or are very buggy still.
So under all the skins and eye candy. Linux is more advanced. There is so many tiny things that put it in the more advanced category, not just the native multi-desk support. Windows has some sweet themes though and StyleXp and Winblinds do a fine job. Linux you add a widget(adesklet) script and thats about it get to start adding the widgets(adesklets). Windows your adding even more on top of the shell, to even start a widget, not just running a helper script( for semi automation oof the install).
Edt:
How to add toys in a Linux desktop:
http://adesklets.sourceforge.net/desklets.html
To add toys in MS:
Well if you want to read a very long list and then buy a product..
http://www.wincustomize.com/
The icons do not count, neither does the colors. Since that is so easy to come by and change. Windows is hard to modify the core icons too. You need special software to do this. So comparing the interface look as more advanced is not as a robust argument as one would think. I do nto use the shading or fancy drops that are in windwos. Yes Xp is supportive of this. Though it does not make the interface more advanced. It how it handles basic tasks to get the cool effects and keep it stable.
