- Dec 29, 2016
So who wants to take bets on how long the motherboard is going to last?
You were taking chances at stock running that board, but overclocked, you're going to cook your vrm's quite fast and I would mentally prepare to lose that motherboard sooner than later.
As long as the temps are OK you'll be fine IMO. Yes it's a 4 phase board but you're only running a 6 core CPU. A mild OC shouldn't be too much for it.
I'd imagine quite a while as I've got an m5a97 that's been running the OC in my sig for close to 5 years now.
Do you have m5a97 LE, R2.0, EVO??? The LE is the worst of the bunch. People get SO defensive about this. The board is not intended for overclocking (even though it "can" doesnt mean you "should"). 4 phase VRM that has no cooling is likely the biggest issue. If you're actively cooling the VRM's you would probably be ok.
It's a 1st gen m5a97 and not an LE, R2.0 or EVO. I'm not actively cooling the VRM's however my rear 120mm sits just to the side of the VRM and it helps pull heat away extremely well.
