Alaric
- Dec 4, 2011
- Satan's Colon, US
First , I picked one of the worst chips to learn with (Phenom X4 9850) , then I went through 3 POS PSUs , discovered my mobo was marginal and used soon to be obsolete RAM (DDR 2) , and topped it all off with the worst performing air cooler I've ever seen in action. Instead of a ribbon , I wrapped it all up in some cheap case that wouldn't flow air if I nailed it to a tree during a hurricane with the side panel off. I decided to be an "Overclocker!" with what was a very anti-OC pile of parts. If enthusiasm were cash and knowledge I would have built a Cray........
Fast forward to one year ago-after a series of disasters I have no internet , no money , and up to my neck in in-laws. This intolerable situation finally seems to be turning into a funny story instead of a living nightmare. Four years after (I thought) I had begun this journey , I'm assembling a starter rig! I might play around a little with clock speeds , but this time I know the limitations going in.
New gear!!!
And my poor , beat to h*ll old case , already modded for water cooling. The side panel was the only place it would fit. If my budget doesn't allow for a new case , I'll probably "adjust" the top panel to accomadate the radiator and get a new piece of plexi for the side , or just screen it for airflow. The slots in the now red metal arm were cut freehand with a dremel , as was the opening for the Corsair H100i.
Now I have to figure out how to convince Mr. Gate$ that he should activate my Win 7 again , because it isn't really a new computer. I mean , it's the same case fer cryin' out loud! Right ? I'm hoping that all the WHEA-Logger AMD Northbridge failures in the event viewer will convince M$ my CPU was a goner-and no AM2+ processors available from AMD meant I had to go AM3+ for a new one , requiring a motherboard , and DDR3. Hope it works , I'm too old to learn Linux......
New gear!!!
