I really don't any answers for you then, I just opened it up to check and see and it worked fine. What about using Ai Suite? Note though, Ai Suite is known to cause issues, I can personally attest to it. My CHV when Ai Suite is installed, will not shut down without hitting and holding the power button on the case. When using "shut down" in windows it will close windows but the fans and rest of the rig will stay running.It should be the latest version, just downloaded it off amd yesterday...
Not with me, it was happening with me even at stock. Remember way back when I first bought the CHV I was having this issue every time I went to shut the Pc off? I think it was C/D that found out that it was possibly Ai Suite and as soon as I un-installed it my issues went away.If you revert it back to the original clocks that usually helps with that Manny. I have the same problem with it but typically it's a crash as well so no chance to change TurboV back
Kk, I'll give ai suite a try a little later today.
Also true, I only use AI Suite or Overdrive on my benching rigs, for daily Oc's Bios!RGone...
EDIT:
I had left and came back to the post to write this. Ai Suite can be such a pain, that I suggest not really installing it unless there is "nothing" left to do. I would overclock in bios since it seems better to most and you are not likely going for a world record and cannot boot windows at some hugely elevated cpu speed.
END EDIT.
I hear ya and drip drip on the Gpu is not so good!problem as humidity or condensation, kinda one in the same, became obvious to me along time back using ss phase change cooler.
attempt 24/7 rig as beginner and get a drip on gpu.
not fun actually
I know that dyckah is working at becoming a bench team member. So a suggestion to you D, use a second HDD/SSD for benching. Anything will do cause you're going to ruin your OS it's not a matter of if but when.
