It's better to just remove the IHS, as then you see the difference in thermals. Lapping barely helps, or you have to make the IHS very thin, and it's a lot of work to make it right. The only problem is finding a proper cooler with a fitting mounting kit. You will be limited to liquid coolers or something like Noctua with a mounting kit for delidded CPUs. It fits perfectly, but it's still not worth to delid lower CPUs.
Ryzens (non-X3D) boost to 95°C, but for the best results, you have to lower voltages and use some other settings. Then you can make the CPU run at about 90°C and keep max clocks for longer or simply boost higher.
