Unsafetest, how you like it? I'm using 5.02, seems most all the settings stayed the same with the update. I had some flow rate issues with my cooling loop, that Tygon 35?? plasticizer free tubing ended up not being compatible with distilled water and kill coils, might of been the Wal-Mart dish soap I used to sterilize the loop also, but it leeched plasticizer that strangely enough picked up the dried gunk left over from the nickel plating process which appears black in nature. I found loads of it gummed up in the CPU fins, so it was complete tear-down and scrub all the blocks and then bend new acrylic tubing so it's an all acrylic loop, that sucked. But now my loop is flowing like it should and now I'm getting system lock on the 4.8 OC I had. Is it possible to overvolt your CPU_NB?
I try not to use it all the time, but I like some of the features it has, mainly reading the CHV-z voltage sensors HWMon doesn't see.
I still have work to do on my Big truck, my dad semi was in the shop and when we got it back it had some wiring issues, so all day Monday I was wiring up lights on his truck and some of Tues. Sitting out in the sun working isn't for me, and that why they make 8x8 portable awnings, love them things.
- - - Updated - - -
I actually miss the old days when I could fit in the engine compartment and wrench on something with my dad. Not only have the engine compartments gotten smaller, but I've gotten bigger, gettin old sucks sometimes. I think engineers don't like mechanics, it really does seem like they are makin it harder and harder to work on your own stuff these days.
