K7N2 delta-L temp problem?
splateee
Texas
Hello everyone,
is there an issue with this mb giving false temp readings?
The reason i am asking is that i am runing at about 48c to 50c & system temp is around 32c it used to be 23c and i am not even overclocking and my system is watercooled. These readings are from MBM5.
I am running a XP barton 2500.
My previous system was a xp 1800 clocked to 1.7ghz with the same watercooling setup and the highest it would get is 36c and that was after alot of Quake3.
This is all in the same case with the same system fans, nothing else has changed.
Im guessing that this is a mb issue and should figure that it is about 8c deg off and shouldn't worry to much.
I would appreciate any help and info
Thank you
splateee
splateee
Texas
ok now that is more like it......
went from 48c cpu to 33c, what a difference.
thanks
