- Mar 14, 2013
- Massachusetts
Alright! So a week or two I picked up a pair of 780 Ti Classifieds and I want to get them on water once the tax man comes back on that annual positive note.
My current setup is a Swiftech Apogee Drive II which is a block and pump combo. The integrated pump is a MCP35X. The current res is a Swiftech MCR-320QP with integrated reservoir mounted on the top of my HAF 932. Both of these components will still be used with the end result of the final loop.
However, as we know the sole radiator is not enough for both GPUs. Here is where the first question comes into play. I want to mount another triple rad externally using a Koolance rear mount. I'm thinking about the Alphacool UT60. That plus the Swiftech should be sufficient for the three blocks. My first question is, do you think an MCP35X has enough muscle for the following...
Swiftech MCR-320QP w/ Integrated Res
Apogee Drive II Block (this is the block and pump combo)
2x EK 780 Ti Classy Watereblocks
Alphacool UT60 Triple Radiator
Angled Fittings in various places (need to map this out further)
Quick Disconnects in various places (need to map this out further)
Also keep in mind that there will need to be a decent amount of tubing to reach the externally mounted radiator from the bottom area of the case. It would run from the bottom GPU up the side of the case out the rear holes into the top ports of the radiator which will be mounted so the top ports are close to the top of the case.
Now second question which I'm pretty certain I already know the answer too. Do you think, and my guess is the answer will be no, that my current integrated res will be enough for the components above?
If both of those answers are No, than I would most likely purchase another MCP35X and Res combo. I would then wire the second motor to the same PWM header as my Apogee Drive II so they would run at the same levels to keep things even.
As you can tell I am in the very early stages of planning and have no intention of rushing this. Planning is key as we know.
Thanks in advance,
Matt
Thanks in advance,
Matt
