- Oct 29, 2005
- Oregon
Iv'e been running MX (no systemD) for a minute now and it is a rather nice system. I especially like the ability to create a live bootable iso of the running system which I can as well use for reinstalling should I get into a jam. Other than resetting my data drive boot options so it's seen at boot with r/w abilities (it's still ntfs), and my wallpaper options in Variety, the bootable iso IS my backup scheme. It works perfectly too provided you keep a copy of the "Installer" script. The iso itself has persistence so I can conceivably also use it on another system should the need arise. Plus it takes almost no time to create considering the OS has a minimal amount of software.
Hopefully once I'm dual booted maybe the iso can also include the windows part. Don't see why not since it'll be the same drive. That will also preclude worrying about a windows backup scheme which has been a pita forever. Windows backup yeah right. The bootable live iso of a running system is imo, THE perfect backup scheme. To hell with acronis, macrium etc etc. Too much hassles.
I plan on parting my msata so I can put windows on the first part and then put MX back on the second half with grub installed to the windows part for a dual boot setup. I need to do this so I can free up my windows7 tablet from running all the time just to watch TV. I kinda wish I had bought a std ssd evo instead of the msata as the msata cannot be over provisioned using samsung magician. My cyberpower ups kicked the can. I do not want another either. What the hell did I spend $200 on a ups if it simply fails with no warning whatsoever and no indication as to why? It was like half the plugs stopped working and the reset button may as well have been glued in place for all it was ever worth. I don't care if it can be 'fixed' as I do not want another cyberpower surprise. I bought a different make with a 2000vA/1000W capacity for about the same cost. It is much simpler in it's design but still has software to monitor itself and with a 3yr warranty. This has put a hold on getting more stuff for my nas but without a ups, I can't conceivably run the nas 24/7 without a ups first.
