- Jul 4, 2004
- Auckland, New Zealand
So ive decided to take the plunge in the deep end and go to some LN2 cooling for some quick suicide runs/benches, but I had a few questions because..well, since im currently running on stock cooling, im not to sure what taking this big of a jump will be like.
Basically what I was thinking was that I could get a block of copper, lap it smooth; create a copper tube and get it welded to the block. That should be no problem to handle. Insulating with foam will be easy as well. As for mounting it, I'll have to figure it that out when i come to it. Getting hold of the LN2 should be no problem either, thats been sorted. 30L should do for a good days benching im thinking.
Now where I get hazy is what I should be doing about condensation.. Ive read there you need to put some dielectric grease on the CPU and socket and surrounding the socket.. but on the toms hardware 5ghz project video, I couldnt see any grease at all when he was using LN2, so whats the deal with this?
My next problem is that I hear that Venice's have the cold bug.. i cant remember if this is true or not, i get mixed responses about that so yeah, does anyone know if the cold bug is present? If it is, ill be usingthe LN2 on my fully unlocked AXP2000+, but id rather it be on the venice.
Anyway umm summary:
1)What precautions should I take for condensation other than foam/a heater running on the back of the mobo around the socket.
2)Do the venices have the cold bug?
3)Anything else im forgetting other than general safety precautions?
Thanks for any help, Id really love to do an LN2 bench, as im sick of stock cooling, and I wont be able to get the swifty APEX h2o kit for a while, so why not?
Careface*
Anyway umm summary:
Careface*
