Won't even boot at 1200mhz @ default voltage it gets so hot, currently underclocked to 1050 @ 1.67V. idle is 52C, running prime95 gets up to 84C! cooler is globalwin fop32, fan rpm is at 4500, mobo/case temps are 21C/26C
a few facts to help find a solution:
-fop applies a lot of pressure, clip is very hard to get on
-bottom of heatsink is flat
-grease layer is thin, it's semi transparent
-Vcore is another strange thing, when i set in bios to 1.75 it actually goes to 1.85, currently i have the bios voltage at like 1.6 and actual turns into 1.67
-temp probe is under cpu, abit kt7-raid mobo
-fop is flat, and centered
-i removed the gooey thermal pad from the fop, and there is no residue, i cleaned it with alcohol
-im not using any software cooling
-my last 1.2ghz cpu had the same problems... then it fried.
-yes its really a 1.2, i checked, and so was the last one
