- Nov 15, 2009
- Wollongong, NSW, Australia
hey guys so over the last month and its picked up a bit this week, my computer has been ****ting its self. first of all ive had enough of ati as their software and drivers make getting eyefinity/crossfire to work properly a major pain for me. i realise nvidia also has their own issues but tbh i just think nvidia have got their **** more organised than amd. next is my cpu/mobo/ram seem to be dying. my cpu used to be stable at 4ghz, then 3.8, then 3.6 and now its not stable at any overclock so im currently all stock settings. i also have a gut feeling my mobo is dying.
the whole system is roughly 2 years old now and ive been waiting and waiting for ivy bridge after reading about it a year ago. im pretty experienced with dealing with problems like this by either coming to you guys or figuring it out my self, but honestly i just dont think theres a root cause for all these problems im having. the gpus seem to be stuffing up and im not sure if thats because of a mix of software and hardware or just hardware alone. theyre only gpu WCed so the rest of the card is exposed, however ive got a pretty ****ing good airflow system in my case so i doubt theyd be overheating, but i may be wrong. this is why i also dont think anything on the mobo would be overheating either.
my drives seem fine, theyre less than a year old and SMART hasnt said anything about them being wrong and neither has intel storage matrix or whatever the **** u call it. sound card is like 3 years old and stick banging, seems to be ok at least. i havent been experiencing any unusual behaviour with it anyways. my psu gets pretty hot in one section of the back of it and the fan never changes speed. ive had a problem with one of these psu's before and had to get an rma on it. i only have it because its dirt cheap since its only meant for my case. i have no idea how much wattage my comp uses and i dont know how efficient my psu is anymore. i plan to get a wattage wall plug reader to check this, but yeah it may also be possible the psu is dying.
tl;dr im having a lot of problems with my computer and there could be various problems with all the parts
i dont really know what to do. if i do anything its gonna cost money, a lot.. i have a feeling if i wait for ivy bridge and even the gtx 600s/700s/whatever theyre gonna psycho expensive. provided my 5870s worked nicely in crossfire i dont think id need to upgrade at all, but they just dont co operate. they also struggle with **** in eyefinity because i dont think 2gb is enough for 5760x1200. i have no idea how i managed this when i only had one 5870. do you guys think i should just go with sandy bridge or wait for ivy? also any thoughts/advice on anything else ive said would be heaps heaps appreciated cause im really feeling down about my setup atm.
thanks guys
thanks guys
