- Jul 26, 2005
- Vancouver, Canada
mysterfix said:It is my understanding that when you are overclocking you would only use a divider when you have to. Like for instance when your cpu has reached it's limit you would use a divider to either push the FSB or the ram or both to there limit also.
u are talking about a down divider.
For AMD skt 939, this was the case. Cpu would run at say. 300fsb while the ram would still have to run at stock, or slightly higher.
Now, with these ddr3, they are like a cpu. A cpu uses a multiplier to multiply the fsb to attain higher speeds. Same idea. By using an Up divider, you fsb may be 500mhz, but your ram could be 1000mhz.
