Microwave oven Screen for Window Mod
Tecumseh
Ohio
Do any of you know where to get screen material like
on microwave ovens?
Your window mod may be causing a lot more EMI than
you believe. It would be cool to cover the inside of
the window with this screen to knock down the EMI
and have blue LEDs glowing inside.
Tell the friends that your PC was so OC'd that you
had to install a shield. :D
BigRed
Caffinated Member
Mount Vernon, WA
hmm i could use this for my monitor mods instead of the ugly tin foil i have wrapped around stuff now, lol.
anyone know where to find this stuff?
T
Tecumseh
Ohio
OK, there seems to be a misconception here.
The lower the frequency the thicker the shielding
needed to be. For low frequency stuff like pumps
at 50-60 Hz shielding the magnetic field would
require very thick metal or the stuff called mumetal.
For the high freq stuff the screens should work fine.
Ichelo351
PA
yeah thats a good idea, i have been wanting to mod my case with a window, but knowing what potential dangers the emi/emf can do, i have been kinda not ready to, but if you can find a place to get that stuff please let me know, then i will be able to mod without worrying at all.
kevin_bouchard
manitoba
you can try using bug screen(the metal stuff) and ground it to your case.
It also works good if you put it in front and back of fans :cool:
But dont forget that it has to be grounded to give rotection
ColdMiser
Georgia
Someone please explain the scientific principles behind EM shielding. Why does it need to be thicker for lower freq stuff? Why will just a screen suffice for high freq stuff?
Crash893
"The man in black fled across the desert,
couldnt you just use metal screen like from a screen door?
Crazy Jayhawk
Hutchinson, KS
Somebody (can't remember who) is probably going to show up with a picture of his window-modded computer with this weird electro-glowing thing next to it.
Unless your monitor is right next to your computer, EMI isn't that much of an issue.
Ichelo351
PA
its not only a matter of emi/emf getting into your computer, but i think those of us who are concerned with it are mainly concerned with the emi/emf getting out of your computer. there are reasons that the gov. has regulations on how much emi/emf a product can emit and be called safe.
for 2 reasons you wouldn't want the emi/emf getting out, 1. potietial interfierence with other divices around it, and 2. possible damage over time to the person.
T
Tecumseh
Ohio
This has to do with the way EM waves interact with the
electrons in the metal. Lower frequencies have a greater
penetration depth thus need a thicker shield.
As a practical thing you can't shield against 60 Hz. If
you have a pump or an old printer power brick causing
interferrence the only thing you can do is move it away.
The microwave screen or a tight-mesh bug screen should
be fine for keeping EM inside your PC.
Crash893
there is noooooo need for keeping emf emi in side the computer
it doenst pump out nearly enogh to interfer with anything
mabey ifyou put your cordless phone right on the heatsink mabey youll get some static
but other than that there is no need to worry
Ichelo351
PA
but on the same notion, doesn't most of the emf come from the processor? so in theory if you were to ground the heatsink, it should block most of the emf.
maybe?
Crash893
yea but if you shock the out side of your case it could fry your cpu
Ichelo351
PA
ummmm, may i ask how?
in theory, the shock would go to the ground before the processor i would think...
Diggrr
Underwater Senior Member
My Matrox dual head video card came with a ground wire on the heatsink (and no fan)...it has a plugin for the wire built into the card's circuitry. Maybe it wouldn't be such a bad idea for the cpu.
My $.02
CrystalMethod
Senior Band Wagon Jumper
Montreal, Quebec, Canada
... right under your noses all the time, unless you've already thrown them out. The anti-static bags your motherboards usually come in, also shield from RF if you can find a way to ground it to the case.
Ichelo351
PA
that is a really good idea about the anti static bags... and i think you are right...
and with the grounded heat sink, yeah i think that would work, i am going to run a ground to mine tonight, will tell you tommorrow if it had any bad effects
