Mobile Pentium 4 on a desktop computer stuck in "battery-optimized" mode
A few days ago I ordered an Intel Pentium 4 2.8 GHz processor to replace my old 2.4 GHz. I just now received it and put it into my machine. It ran perfectly fine, but when I checked what clock frequency it was operating at I found that it was only going at 1.6 GHz. Annoyed, I subsequently discovered that the part I ordered which I had thought was for desktops was actually the mobile version and it was stuck in "battery-optimized" mode which limited it to 1.6 GHz.
I've been looking around trying to figure out how to disable battery-optimized mode so it runs at 2.8 GHz instead of 1.6 GHz but I haven't had any success and I really don't have much experience with this sort of thing so I decided to post here for your guys' advice. How would I do this? Is it even possible? Note that my motherboard does not support SpeedStep. It also doesn't support Hyper-Threading which the processor has as well (again unbeknownst to me). What are the drawbacks, if any, of using a mobile processor in a desktop motherboard? Should I just send this piece back and order the right one? I would rather not go through the hassle but if I can't get this CPU past 2.4 GHz it's worthless to me.
Update:
As far as I can find out, this problem cannot be remedied through software or BIOS means. However, there is one possible apparent hardware solution which, unfortunately, I have absolutely no clue about. Can anyone interpret this? (and the posts below it):
Adjusting the multiplier on a P-4 Northwood
As well as here:
Max. mulitplier P4 mobile
A few people pulled it off successfully. How would whatever the hell they're talking about be done?
Thanks.
Update:
As well as here:
Thanks.
