- Dec 22, 2000
Ok... so there is the freezer... 4 sides and a bottom. If I am going to use this as a water resevoir, I thought I better maximize the cooling part of the water. So what about this....
5 giant waterblocks fitted for the sides and bottom and setup to run in sequence. First the warm used water is dumped into the middle of the freezer. Then the water is then sucked through the bottom, then the sides, and back into the computer. I mean even a small freezer should be able to handle the heat load of the cpu, gpu, and northbridge right? Because if you just have a big tank of water, it won't be cooled nearly as much. Am I wrong?
