sm0x said:Actually I was thinking of using AS3 on the core and super glue on each corner of the heatsink to mount it. How about that?
sm0x said:How about using a hot glue gun? You think the card will get hot enough to melt the glue?
Maxvla said:whats so hard about ordering some artic alumina from newegg etc.?
rlemieux said:I would not get the TT one as every review I have seen shows it barely outperforms the stock cooler.
I marked my Cooljag for mounting holes, never drilled them, but it would have been easy enough. Just use the card to mark the holes, drill some 3/16 holes, bore out the fins around the holes(about 3/8 or so) so the screw fits down inside the fins, and get some 1/8 plastic screws and washers. Use some AS3 and tighten the screws down.
Its really only good for the RAM sinks
sm0x said:
Whats the main difference between AS adhesive and arctic alumina adhesive? Does alumina conduct less electricity? Also if I mix any one of those 2 with the Artic Silver Thermal Compund I should be able to get the HSF off right?
Thanks
rlemieux said:it would, but as soon as you mix AS with the AA adhesive it becomes conductive, and you dont want that.
