Hello dear all, I'm trying to update my MB BIOS to the last version because Win 11 is unable to choose the right GPU for low consuption or high performance, it use or the embedded or my 7900 XT on both position. I used to have a MSI MB with Intel chipset and Windows 11 was perfect on manage the embedded GPU or the high performance(6800 XT) when necessary
I have aslo some doubt about fans management, because even if I set the PWM value to 0 until the 30 Celsius they dont go under th 650rpm, only the Arctic freezer II 360 ARGB go slowest, more ao less around 250 rpm as minimum
I've enabled also the "STOP" function for every fan but it doesnt work.
Any suggestion/solution?!?
