Well if you pump has suction cups yes, for the rad either screws or zip ties. As for the res well thats really up to you. I've had a 4x4x4 junction box as a res in my case and now I have a 5" long 2"PVC as a res thats on the outside.
Well without some pics it is hard to say but it sounds like you are on the right track. I have never used suction cups to mount my pumps but I would say keep an eye on them to make sure they don't come loose and let your pump move around.
The core should be fine with screws. I usually just use long zip ties but your setup could be even better. The res depending on your setup most likely will need a cover jsut to keep the crud from floating in there and going into your w/c system.
Most important: Make sure to leak test for at least a day. Have fun!
