The only problem you might have with a pump inverted or at some funky angle is air bubbles getting trapped in the chamber. However, once the system is bled there shouldn't be any issues.
A slightly tilted orientation may increase the vibration & noise it makes though. I've had best results with the standard horizontal inlet and vertical outlet orientation myself.
