Hey guys. Been lurking for a while and now I am going to pull the trigger and build a kick *** machine. Its been 5 years since I built a PC and 4 years before that. This is a long post! Hope it doesn't bother anyone but I will be tracking this build and hopefully posting some kickass temps and scores in the end.
So there are a few things I want to correct with my build this time around.
1. I am going to finally build a dual loops full WC setup. EK blocks for CPU, GPUs, NB, and VRM.
2. I want a clean, quality, aesthetically pleasing build. Clean cabling is a must. I dont want to plug anything in my bays unless it matches the tower. If that means no optical drive then so be it. This is a popular tower surely I can find parts that wont stand out with different shades of black. I am dishing out a lot of time and money on this build so I want it to be a work of art.
Specs:
Missing: Tubing, Radiators, Reservoirs
1. The radiators. Cant decide between a dual radiator build 360+240, and a single radiator 480 build. I am leaning towards a dual radiator build since I am assuming that you cant get as good TDeltas (as dual radiator loops) on a thick 480 without high RPM fans. 360 - XSPC RX360 + RS240 or Black Ice GT Stealth 360, 240.
2. I want one of those dual bay dual pump reservoir combos. Do you think a better choice to get the reservoirs out of the drive bays and mounted inside case? I like the idea of seeing that coolant on front of case but I dont want that to come at the expense of mismatching drive bay tenants.
3. I want quick disconnects on radiators for cleaning purposes (do I need any anywhere else?). Ive read posts that suggest that they hurt flow rates and have a chance at leaking. Is this true?
4. Trim the fat! What are the wasteful areas of this build? I will admit that I am new to watercooling. So I did enough research to find the best part designers and got their top of the line products with the assumption that I will get professional opinions and cut things that are unnecessarily-expensive/better-spent-elsewhere
Also a question on algae/corrosion. UV Reactive/dyes look nice. Really nice. But it seems like they add a lot of overhead in terms of maintenance. I don't have that time. Some people say that we should go for completely solid tubing in order to prevent algae. Whats your take on this? Is it enough to cut the UV reactive coolants but keep the tubing? Or is it best (in terms of minimum maintenance) to just go with solid tubing?
Ty for reading and replying!
Specs:
- Case: Corsair 800D
- Optical: External.
- CPU: Intel SB EE 3960x
- Mobo: RIVE
- Memory: 4x4 Corsair Dominator/Vengeance
- SSD: Corsair M4
- HD: Western Digital Caviar Green in Raid 5/10 (depending on budget)
- GPU: Hd Radeon 7970
- GPU Block: EK Acetal + Back Cover
- Blocks: RIVE EK Acetal Electroless Nickel Plated -- EK Supreme HF - Electroless Nickel Plated
- Fans: Scythe AP-15
- Radiator 1 - XSPC RX360
- Radiator 2 - XSPC RX240
- Tubing - PrimoFlex White 1/2"ID 3/4"OD
- Fittings - Specifics are still WIP. Plan: Quick release for radiators and reservoirs, compression fittings for the rest.
- Fan controller - WIP. Still trying to find case match.
- Reservoir - WIP. Still trying to find case match.
- Pumps - MCP35X
- Fittings - 16x XSPC compression fittings, 2x T connections, 2x fill-in port
- Beautiful pc. Seriously. I will not be able to live with spending this much money on this thing only to have mismatching drive bay crap. So any help finding matching optical drive, fan controller, and (if we go with drive bay reservoirs) reservoirs would be GREATLY appreciated!
- Keep the parts internal.
- Capability to go silent (slow down fans, pumps, etc). The plan is to go into hyperdrive when I need it and slow everything down when I am doing general productivity.
