- Nov 4, 2010
- Bay Area, California
ROUND 2:
1 - CPU Block - Koolance CPU-360
I chose this partially because of the aesthetic, and because of this review at Skinnee Labs.
2- GPU Block - MCW80 GTX470
I chose this because of the aesthetic and because of this review here on OCF.
3- Reservoir - XSPC 5.25" Bay Reservoir
I chose this because it fits the color of the case and allows for reading the water level. My concern is that because the top isn't sealed, something bad may happen. Might seal it with a plug. Thoughts?
4- Pump - Koolance PMP-450
I chose this because through my research I found that the two most popular pumps (this and the Swiftec pump) are both based on the same model with very slight differences between the two. I was thinking of putting it in the lowest 5.25 bay, but I think it looks better at the bottom of the case.
4- Pump Top - COV-RP450
I chose this because of the aesthetic. I think the bare pump looks a bid rough, this review at Skinnee Labs does show that it cause a very small drop in flow though. Though the model # is different, the link that Skinnee links to is the COV-RP450
13- Pump Seat -Gel-stuff Block
This is to reduce vibration. Any thoughts on this?
5 - Bottom Radiator - HX-CU720V Koolance 2x120mm High Flow Radiator
Supposedly provides up to 700w of heat dissipation. If I ever change to a SLI configuration, it should be enough to create a 2nd loop for 2xGTX470 assuming each outputs 275w of heat. My concern is that because these are low to the ground, they may not be operating optimally. In this case, it would likely cool best as a single loop, yes? Could not find any reviews for this specific rad. Case will have to be modded. I will be using 2000RPM fans.
10 & 11- Bottom Radiator Fans - Koolance 120mm 2000RPM Fan
I picked these to save on shipping from Koolance. They seem alright based on their specs. 89CFM 30db @ 2200RPM
14 - Filter - DEMCiflex 120mm Magnetic Dust Filter
I picked this to filter the dust since these are facing down. These were used by a few 800D builds like this one.
6- Top Radiator - XSPC RX360 3x120mm Radiator (Low Flow)
I picked a low flow radiator at the top, because these are closest to me. This makes me think they might be the loudest. I picked it based on this from Skinnee. I will be using 1500RPM fans. I'm wondering whether or not this would benefit from push-pull in such a tight enclosed space.
7, 8 & 9 - Top Radiator Fans - Aerocool Silver Lightning 120mm 1500RPM fans.
I picked these for the RPM, CFM (65 & 26dB)
12 - Drain Valve - Koolance Drain Valve
This was chosen to split the line from the GPU-out to the Bottom RAD-IN for easy draining. I'm looking for suggestions for what to replace this with, if any. I will most likely be replacing this, as this is meant for 5/8OD and I'm thinking of going 3/4ths.
13-Ball Valve - Koolance Ball Valve
This ball valve was chosen so that the flow from the drain could be controlled when necessary. Would normally be closed.
15 - Some kind of plug for some kind of redundancy in safety.
A tube would run out a bit, so that I can pull it out of the case and into some kind of bottle or something for draining. A plug would be at the end for double safety.
16 [& Other white blocks] -Compression fitting nozzles -Koolance Compression Fittings [ID1/2 OD3/4]
All the white blocks marked are compression fitting nozzles, any suggestions for replacements to these for specific ports is welcome. I don't want to go the route of barbs.
17 White - I believe the pump comes with nozzles, so these are marked as separate for reference.
17 Red - Quick Disconnect Female - Koolance VL3N Quick Disconnect Female
These were chosen because of this review at Skinnee Labs. I want to be able to remove the CPU and GPU easily.
17 Red - Quick Disconnect Male-Koolance VL3N QUICK DISCONNECT MALE
X - Some 140mm high RPM fan to improve airflow white LED?.
Other thoughts:
I've heard the 800D's airflow is bad. Hopefully the new back fan is enough for cooling the memory.
QDC on the res for easy removal and filling?
I'm not sure how I feel about the port on the top, I want to plug it up.
I'm going on vacation in a few months. If I do get this built before then...will the sitting water attract mosquitos and other things like that?!
Push-pull on both the rads seems like a better idea, but I'm not sure if I should.
Chipset & VReg cooling...totally unncessary from what I've read. I'm not sure what to think about it exactly.
Other thoughts:
http://img.photobucket.com/albums/v496/m3isdeath/cooling-2.jpg
So I've read all the stickies and gathered as much information as I possibly could from a multitude of different forums and threads, and here's what I've come up with.
How does it look? Anythings that need to be changed, etc? Also, the things that connect between two SLI-GPUs together...do they come with the block?
Any input would be appreciated![/QUOTE]
