- Jan 14, 2010
My liquid cooled PC just failed!
The water pump just went out, it stopped that’s all. I was reading and this PC just shut off, First thought was the electric power went down, but right next to me is my other PC and it is still on. (WOW)
This is just ( FYI) for liquid PC is all.
I felt the water block on the chip and it was hot, so I waited and rebooted it and got a F1 error message; I felt the water pump and it felt pretty hot also, but I rebooted anyway just to see what’s up.
Got F1 error fan not working: this same location for a fan is where the water pump is hooked to the mobo.
I pulled the whole mobo out to get the water cooling mounting gear off and mounted a big aluminum heat sink, snapped on a fan and tunnel ram, booted up and now I gotta noisy extra fan in my PC.
I guess the point is about what happens to a liquid cooled PC when failure accures.
In this case overheat and bios temp setting auto shut down.
Water pump brand is Corsair and is only 13 months old.
I have also Corsair memory and a Corsair Power supply without any issue there, so don’t negatively judge Corsair.
Anyone else have this happen?
This is my first liquid rig, but I would think that the water pump should last longer than 13 months!
I am about to open the pump to see if anything can be fixed or if it is just disposable.
Thanks for reading
Thanks for reading
