- May 7, 2004
- Wisconsin, USA
Alright, I've done some research and some shopping and I have a list of thing I want to buy. As the title says, this would be my first W/C rig, so any comments or suggestions would be appreciated. I suppose I should mention that this is for the computer listed in my sig below.
Case: CoolerMaster Stacker
I need something big enough, and I like this one better than the Armor.
Water Block: Swiftech Storm Extreme - Rev 2
I like the upgrade potential with this one. It seems to have gotten good reviews and I've been a fan of Swiftech's air cooling for awhile.
Pump: Swiftech MCP655 12 VDC Pump
Same reasons for this as for the water block.
Radiator: Black Ice XtremeII
It's the right size (2x120mm) and seems to be a good radiator. Plus, it seems hard to justify that almost twice as much ThermoChill PA120.2.
Also, Danger Den sells a CM Stacker Bottom Case Shroud which seems to be perfect for mounting. However, I haven't been able to find anything specfic about it. Are there any Stacker owners out there who have purchased this thing?
Reservoir: Typhoon Dual 5.25" Bay Reservoir
Since the Stacker is so big, this seemed like it would be right at home. I'd like to go with a reservoir, and this one seems perfect. It fits in 2, 5-1/4" Bays.
As far as tubing and clamps, I saw some PrimoFlex 1/2" ID, 3/4" OD PVC Tubing over at FrozenCPU.com that looked decent. I figured I'd just buy some metal clamps over at a hardware store.
As far as the actual water goes, I figured I'd use an ~75/25 water to antifreeze ratio. I'm still up in the air as to which additives to add, so any suggestions would be appreciated here as well. Also, is the Fluid XP+ stuff worth the money?
Finally, I'm also picking up another tube of AS5. Ahh AS5, where would we be without you.
Like I've said, any suggestions or comments would be appreciated. Let me know what you think.
Thanks,
Lejend
(edit: Grammer)
Thanks,
Lejend
(edit: Grammer)
