- Jan 7, 2006
Hi, I dont know where to begin, so Ill just start rambling on
I got a 19" LCD Sceptre x9g komodo V from tiger direct
and although the pixel pitch (wich I didnt understand the importance of) has kind of got me down, if I had it to do again Id just go 17 inch for better pixel pitch so games like Rome wouldnt look ugly
but heres the situation, my games now have to be played at 1280 by 1024 but my old Gforce 5500 just cant handle it, I only average 25 fps on Americas army, so Id like to keep it that way, but uping the resolution ripps another big chunck out of my fps
and also with the increased pixel pitch, anti aliasing, especially in rome total war is now something Id like to use
so, Iv been on another forum asking for help picking out a good Card that will help me play my games at 1280 by 1024 res with a touch of anti aliasing
9600 pro seems to be pretty popular suggestion, but then I have to think about what OEM, cuz there is pro, sapphire, XT etc etc, and I dont know wich one is best, but a store in my area has an XT, so if that one were best, it would be convenient
then I have to consider that I am now useing an LCD, so any card with features, or software that could soften the pain of scaleing, or work with my LCD in any way , I would like to know about
does anybody know if any such software or features exist?
ok, so thats direction number one, get a new card, but that has actually become my plan B, so now Ill talk about why I went googleing for an Overclockers forum
Iv never overclocked anything before, and I know the Gforce 5500 is said to have heat issues so its probably a bad place to start, but it just dawned on me tonight while doing more video card research, that if I get a new card now, then my current 5500 is going to go to waste anyway, so why not just overclock the hell out of it and make it work for me, because if it burns out, **** it, Ill just move on to plan B, I was going to have to anyway right?
(I read the sticky thread and it said **s are ok so )
now, for a little more info on where I stand, I installed coolbits, and the factory frequencies are
270 mhz core , 286 mhz mem
ok, so while doing a little stick pokeing here, I hit the Detect optimal frequencies button, and this is what it comes up with
333 mhz core , 417 mhz mem
seems a little high to me, but what do I know, it also for some reason takes the liberty of dropping my monitors refresh rate to 60 down from its recommended 75 when I do this
so, Im not really worried about risking the the life of the card in exchange for increased ability to play games at my monitors native resolution, because as I said, the card is going to have to go if it cant cut it anyway
but what I want to know, what kind of risk is there that OCing the card could damage other system components, as I dont want the card to take my motherboard with it when it dies
and also, I have to wonder if my intended method of cooling this thing is a stupid idea, right now the cards heatsink has no fan because it died and I removed the fan, but I rigged an 80mm fan to blow directly on the heat sink from about 5mm away, seems to keep it cool, that is to say the heatsink never seems to get warm to the touch
do you think an 80mm fan does a better job than one of those little fans? probably but I figured this is where the experience is so I might as well ask
the rest of the project will consist of me going out and buying like 3 ice packs wich I will alternate out of the freezer and some how rig up to the end of a tube, wich will lead to the intake side of the 80mm fan, to keep the fan takeing in cool air instead of shooting warm air back onto the heat sink again
so, I guess I should sum it up now
do you think the ice packs/tube leading to fan will have any effect at all at cooling the air, enough to make it worth useing them, or do you have better ideas that dont involve me buying a cooling device that costs as much as a new card
wich 9600 model would be the best choice, and Im gonna want to go with a 256mb of ram not 128, as I read somewhere that more vid ram is better for higher resolutions, dont know if its true or not
do the frequencies 333 mhz core, 417 mhz mem for this card sound sain to you guys, or am I just as well to take it out and stomp on it as to set those frequencies
will Over OCing my card risk the life of my motherboard
does anybody know if any such software or video card features exist that improve images that will be displayed on my LCD, such as anything that eases the pain of LCD scaleing, or improves DVD/MPGs viewing
are you still awake
are you still awake
