- May 30, 2007
- Austin, Texas
As any MF/RF/P5E owner knows, there's next to nothing to attach a north bridge heatsink to, so getting one on that hot X38/X48 is difficult. I found a guide online for a way to do it and I adapted it a little bit, but didn't take pictures throughout the entire process, so only the end results are visible.
I went and bought some 3" screws at Lowe's that were the same diameter as the motherboard screws. I just brought one with me and found one that matched and I was good to go. I also grabbed a couple rubber washers while I was there as well. The screws came with matching nuts.
The idea was to take out the center motherboard screw and run this long screw through the motherboard, the screw hole, and out the back of my case, where I'd use a rubber washer and a nut to secure it on the back of the case. I'd use another rubber washer and a nut to secure it down to the motherboard itself, so it would be held securely to the motherboard and would also provide support for the board.
Then I'd use 2 nuts to clamp down on the fan once I got it adjusted to the right height. I had to make sure they were tightened about as tight as I could possibly get them to cut down on vibration and clicking noises. Here's what I came up with:
The mod from further out.
Closer in. Link Depot, I know, but at 50mm it doesn't matter that much.
Cable management!
This mod has dropped my NB temps by 10C on idle and 12-13C on load, so it was definitely worth it to cool off one of the hottest components in my system. I'd definitely recommend doing this to anyone who's got one of these boards and doesn't have active cooling on it.
Cable management!
