- Dec 27, 2008
Here you go: http://www.performance-pcs.com/sunb...hannel-30-watt-fan-controller-5-25-black.html
You can't beat that price. I paid about $25 for mine.
Yeah thats my issue.. Plus with a controller, i can add more fans later or upgrade them to more powerful ones without the risk of killing the moboYou can still control two fans with a splitter but not individually.
PPCS was the first place I looked, but the shipping to Canada was ~$30.... So i agree the price is good but shipping is another story.Here you go: http://www.performance-pcs.com/sunb...hannel-30-watt-fan-controller-5-25-black.html
No, you misunderstand. You can use a splitter with a controller. Works fine if the fans are the same make and model as they will respond he same to the same reduction in voltage. The controller has pins just like the motherboard headers. Works the same. Each channel on the controller has its own pin out. If the controller has 5 channels it will have five places to connect fans or splitters in the back. If you want to connect two fans to one channel you just put a splitter in between the fans and the channel header. If you want to put three fans on one channel use two splitters between the channel's pin out and the fans. You can daisy chain the splitters. You can add as many fans as you want to a channel that way as long as the total power draw doesn't exceed the channel wattage rating. Each channel has a separate speed control.
I can't really justify more than $30 for a controller. (CAD$)So what is your budget for the fan speed controller? The cost of the Sunbeam Rheobus Extreme even with $30 shipping to Canada would be <$38 US. The other controllers I linked were like 30-40W total instead of per channel. Which would probably be good enough for average fans. I'm getting prepared to reconfigure my water loop and will be using 4k rpm 3x120x38mm 19 watts each fans so I need a really stout controller. My rad has 30 fins per inch so it should benefit from those fans.
USPS First class international was only $17.50, at least to the town I live in.. And USPS is best for shipping to canada from the us anyways
I'm holding you to that!!You'll like it!
Only thing I didn't care for if I was nit picking is the Led's (Control Knobs) were really bright at night when the fans were turned all the way up. My son is using it now and he likes it that way.
Hmmm... Hopefully its not too bright. Worst comes to worst i van just remove 'em i guess. Thanks for the heads up manny!!
There ya go! Simple and effective!!!Coloring over them with a black sharpie dimmed the lights enough for me!
With speed increase? I should be good then. Might run the fans at 75% max anyways..You can also just wrap electrical tape around the knobs. That's what I did for my daughter's computer with that controller since it is in her bedroom and the lights disturbed her sleeping.
By the way, the brightness of the LEDs increases with the amount you turn up the fan.
