Hello Everyone!
I'm new here and I am currently planning my very first Custom Loop Build. I'm not sure about some components though. This is the plan so far https://geizhals.de/?cat=WL-779111 along various Watercooling components from EKWB (screenshot at the end)
I want to OC the Ryzen to about 4k and the 1080ti aswell as far as I can get while stable. A friend told me this is a bad MB for the money and I should get a different one. He also said I should get a be quiet PSU instead. Please enlighten me what you guys would recommend. If there are any other components you would change please tell me.
I also had a question about the build itself. I was planning to have 2 fans at the front and 2 on top and none in the back. Can I do that? I don't want to have negative case pressure. Also are the fans too strong or rather can I replace two of the with lower RPM fans? Or should I just leave it like this and also add the case fan in the back despite having more exhaust than intake at that point?
Thanks in advance!
Thanks in advance!
