- Jun 5, 2009
- Sydney, Australia
For most of the things you listed you wanted your pc the I5 route is better and saves power too.
Also the only quad-channel capable boards/cpu's are the SB-E lga2011 ones.
Only benchmark an fx8120/50 wins over Intel is the Winrar one too.
Don't wanna start a flame war, but I think atm that's the best choice.
Just look for the desired features in the mobo you buy if you're not ocing, get cheap Samsung 30nm ram kits or whatever good brands you find and you're good to go. H61/H67, perhaps z68 (thinking ASRock Z68 PRO3 GEN3).
Also the Intel ssd or a Crucial m4 are the best choices.
Good luck with your build!
+1
I like amd. I do. I still run 2 AMD computers. Ones a 5000+; ones a Phenom II 720. But fact is right now Intel is king. Even in the low end. Just because of the efficiency and power draw.. Clock for clock Intel kicks bulldozers butt Lol.
