First post here, so be gentle.
I've had a new rig for about a month and a half now. It consists of a GA-Z68XP-UD3 Mobo, i7 2600k CPU, 16 GB G.Skill RipjawsX, and a EVGA OC GTX 570 HD 1.2GB graphics card, all in an Antec 900 v1 case. The stock Antec fans have been replaced with two Noctua NF-P12 PWM for the front intake and 1 Noctua NF-S12B FLX fan in the back. Unfortunately I know of no way to replace the massive 200mm Antec fan on top with something quieter.
Currently, it's running at stock speeds. I've tried using Gigabyte's OC utility, and even setting it on Safe will usually crash the BIOS upon boot. I know from past experience these utilities usually suck, and I need to go in and manually edit the BIOS. I just need to find a good guide to do so...
In any case, before I do that, I need to upgrade the stock CPU fan. On my last Q6600 rig, I had a Thermalright Ultra 90 cooler. While the cooler may still work, I would need to find a a different mounting kit, and Thermalright doesn't seem to distribute one.
I'm considering two other routes... 1) One of the closed loop water cooling kits or 2) the massive Noctua NH-D14 air cooler. Yes, I'm a big fan of Noctua if you couldn't tell.
I'm looking at getting my OC up to 4.5~4.6 range. I know both options will work, but I wanted to get some feedback. I'm trying to keep my system quiet but cool at the same time. Am I best off sticking with air cooled, or are the water loops an OK option? I'm just afraid of one of those water unit's springing a leak. I know it's fairly rare, but you do see those happening in the reviews online.
For the water cooling kits, is the Antec or Corsair kit better? Which is quieter? More reliable?
One note... I know certain versions of those water kits come with software. I'm looking to avoid using that software, as I run this machine as a dual boot system (Windows 7 x64 and OSX). While the software would be fine for Windows, I spend a lot of time on the Mac side.
Thanks!
Thanks!
