First take a look at my lousy diagram, http://www.vulcan4d.f2s.com/pc.jpg
The arrows indicate which way the fans blow. As you can see Air flow in my case sucks, it's pretty cramped in there. The GoldenOrb blows air towards the cpu, but because the power supply is blocking the air flow I get higher temps than I should. I stuck on another 40mm fan right on top of the Golden Orb to have a dual fan combo which helps a bit, but since it's summer the temps still ain't nice. I need some suggestions from ya guys on how to improve air flow in my PC case, withough anything crazy like water cooling
. Just plain fans, that's all. I don't want to replace the case either, seems like a waste
. I was thinking of 2 ways I can improve air flow, tell me what you think?
Option1:
Install 40mm fan on the side of the golden orb to push air down and out of the case:
Option2:
Install 40mm fan on the side of the golden orb to push air up and out of the case:
Option1:
Loading…
Option2:
Loading…
