Yes, a stopwatch is not the most accurate. Any suggestions for something better would be great!
I just dont think that finding the "sweet spot" or "ultimate sweet spot" is worth the time over the advice "smallest partition you can use". IMOG is touching on this with his disgust at the idea of the stopwatch as the differences wont be much at all............................Sure its faster than a non raided drive, but does loading the same amount of data regardless of the partition size matter if its the OS we are talking about at the begning of a drive?
Lets think about it for a minute, and please dont hesitate to correct me if I am wrong...
Regardless of the size of the partition, if your OS/APPS = 30GB and is placed at the front of the drive (which it always is unless its a dual+ boot) then its always going to use the fastest part of the drive regardless of where the partition is. And until your data gets out of the "sweet spot" this shouldnt change the results depending on partition location. Right?
EDIT:
Example
30GB data on R0 40GB partition = xx boot time
30GB data on R0 80GB partition = xx boot time
30GB data on R0 160GB partition = xx boot time
30GB data on entire drive (no partitions) = xx boot time
EDIT:
Example
